New (to me) Bx2380
Kschlegle
Bx2380
Oct 16, 2023
Illinois
My bx2380 seems to be leaking oil from the seal at the front knuckle on (if you’re staring at front of tractor) the left hand side. Anyone ever pulled these apart to replace the seals in there? Is it a pain to do? Or is there a quick fix for it? Any help would be great.
thanks
4,236
probably #060, easy enough BUT you'll need a pair of strong snap ring pliers to get #100 and then #080 out
imnukensc
BX2380
Sep 10, 2015
649
525
Midlands of SC
I know I've seen a youtube video some time in the past year or so about this. Sorry, I don't have a link to it, but a little searching for it and it shouldn't be too hard to find.
xrocketengineer
Nov 14, 2020
695
576
Merritt Island, Florida
If your leak is not excessive, see if you still have the thin UDT transmission oil in the front axle. Switching to the Kubota 80-90 weight gear oil might eliminate the leak. You can tell by the smell of the gear oil which is which.
2,430
This was the same thought I had...why not try it first. What I would do...but I would use any 80-90 weight oil, not worrying about the Kubota name on it... :)
4,365
"I would use any 80-90 weight"
Absolute sacrilege!
This is a KUBOTA tractor!
Must have only Kubota engine oil, Kubota gear oil, Kubota hyd. oil, Kubota filters, Kubota headlight bulbs, Kubota cup holder, etc. :ROFLMAO:
2,430
Absolute sacrilege!
Must have only Kubota engine oil, Kubota gear oil, Kubota hyd. oil, Kubota filters, Kubota headlight bulbs, Kubota air in tires, Kubota cup holder, etc. :ROFLMAO:
Forgive me father for I have sinned! :ROFLMAO:
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
308
98
Nicollet, mn
Absolute sacrilege!
And you must also wear orange briefs or boxers:p
Because the John Deere guys have green ones with yellow waist bands;)
