The early B7100's have an ear on each side, installed on the common shaft beside each lift arm pivot ball. The turnbuckles attach to the ears, one on each side. On newer models tractors, they attached to a common pivot plate mounted underneath the PTO shaft.Hodge,
I am curious about what you design and build your B7100 stabilizer to fit? Do most have these “ears” or not. Does it matter for your design or will it work with either connection? I’m guessing you have the most direct experience here and I appreciate your expertise.
Thanks.
Your into fabricating, you can't just make up a pair?The early B7100's have an ear on each side, installed on the common shaft beside each lift arm pivot ball. The turnbuckles attach to the ears, one on each side. On newer models tractors, they attached to a common pivot plate mounted underneath the PTO shaft.
