Need Help Hooking up Hydraulics on L2800
wgsmiss11
Madison, MS
Hi All,
I'm planning to tap into my Kubota L2800's auxilary hydraulic ports to control a Woods stump grinder and would appreciate some help.
According to the tractor manual, they are labeled "To implement". I get this one - it goes to the input on my new control valve.
The second one is labeled "From Implement (Outlet)" and the third "From Implement (Tank port)"
Can someone tell me which of these goes to my Power Beyond port and the Output port on my control valve? I'm guessing the "From Implement (Tank Port) would go to the output on the control valve ???
And just in case it's not clear, I currently have NO add-on hydraulic driven equipment.
Thanks,
Greg
Jfay
Northeast MA
You have it right. The power beyond port on your valve should connect to the implement out port and the out port on valve should go to tank.
