MX6000 wire schematic?
OrangeWorks
Mx6000
Apr 7, 2025
Ms
Any one have schematics on MX6000, particularly the combination switch for lights?
8,142
Here are some screenshots from the WSM. First one is ROPS and the second one is CAB, both are the NA models.
OrangeWorks
Mx6000
Apr 7, 2025
Ms
There are several versions: North America, Canadian, Cabin, or ROPS.
Yes. I see.
I pulled the plug to the combination switch. The schematic color to PIN numbers are different to what’s on my pig tail.
I know I’m blind but it looks opposite to what’s drawn.
Am I looking at it Wrongly.
8,142
Yes. I see.
Colors are correct, but the order is definitely messed up based on the numbers in the schematic and the connector that you show. The schematic for the combination switch is the same for NA, CA, ROPS and CAB models.
The schematic shows:
1 - Br/W
2 - Or/W
3 - R/L
4 - G/W
5 - G/L
6 - W
7 -
8 - G/R
9 - R/G
10 - G
Your tractor has:
1 - G/W
2 - R/L
3 - Or/W
4 - Br/W
5 - G
6 - R/G
7 - G/R
8 -
9 -W
10 - G/L
OrangeWorks
Mx6000
Apr 7, 2025
Ms
1 - Br/W
2 - Or/W
3 - R/L
4 - G/W
5 - G/L
6 - W
7 -
8 - G/R
9 - R/G
10 - G
Your tractor has:
1 - G/W
2 - R/L
3 - Or/W
4 - Br/W
5 - G
6 - R/G
7 - G/R
8 -
9 -W
10 - G/L
Yup that’s what I saw. Guess I’ll just have to do it with a meter. But it did answer one question.
Headlights does go through a relay. Which makes sense. Takes the current off the switch.
8,251
Look on the switch and see if it has numbers on the terminals?
OrangeWorks
Mx6000
Apr 7, 2025
Ms
Wire colors are right.
Numbers on connector is wrong.
Colors are going to the places they are designated to.
Didn’t want to go to the depth of pulling out switch.
Just found the12volt supply on connector and then jumped to terminals.
B/W was one I needed.
High beam
thanks for wire diagrams.
