MX5800 rear tire ballast
TheJuice9269
Kubota MX5100-(sold) / Kubota MX 5200-(sold) / Kubota MX5800
Oct 14, 2017
26
Freeland, MI, USA
I'm getting Rimguard added to the rear tires on my MX5800. I'm looking at putting wheel weights on it as well. Is that too much weight on the rear end? At 75% with Rimguard, that's about 1,100 pounds and I don't want to monkey anything up. I was going to add 3pt ballast as well, reasonably. Wheel weights are $800 for 4 of them (seems expensive to me) which includes mounting hardware, but will only give me just over 400 more pounds total. I'm getting 1,100 pounds of Rimguard for less than $200.
5,404
Nope you can't put too mush weight on the rear!
But I would be surprised if you will need the three point ballast when your done. ;)
Jim Dandy
L245DT W/Loader M8030DT L275DT
Thanks mbu
Great article on ballast. I had this talk with my dealer. He says you can really cause damage if you get carried away. Also some of the growers I do work for are concerned about compaction issues and don’t want anymore weight in the field and then necessary.
Thanks James
