Mower spindle rebuild
Donystoy
Dec 10, 2013
600
257
Binbrook, Ontario
I have an Ariens IKONXL60 zero turn mower with just over 300 hours on it. Had one of the spindles start to get noisy last summer and upon investigation found a second one getting tight. Found that instead of using Loctite on the bearing retainer nut as in the past they now use a retainer made from an alloy that includes brass. There is virtually no way to remove the nut without destroying the threads. No amount of heat etc would work. I ended up using a 24-inch pipe wrench. This was apparently done to make them unserviceable and force you to purchase the entire spindle instead of just a couple of bearings. I did order the only one available in North America last summer as I was in a bind to get it repaired. At the time I repaired the second one by threading the shaft to a different size and machining a nut of the same size and inserting it into the original retainer after machining it.
I just rebuilt all three with new bearings and did what was necessary to make these spindles serviceable with grease fittings. I removed what bearing seals was required to make it work so excess grease comes out just below the pully. The new one that I bought last summer for $300 will now be a spare.
My 30-year-old John Deere 345 has greaseable spindles and have never replaced any.
je1279
LX2610 w/ 60" MMM, LP 72" Snow Plow, EA Wicked 55" Grapple, and Woods 60" BB
Dec 6, 2020
812
560
Upstate NY
It's truly sad that the vast majority of parts these days are considered to be disposable rather than rebuildable.
