Donystoy
I have an Ariens IKONXL60 zero turn mower with just over 300 hours on it. Had one of the spindles start to get noisy last summer and upon investigation found a second one getting tight. Found that instead of using Loctite on the bearing retainer nut as in the past they now use a retainer made from an alloy that includes brass. There is virtually no way to remove the nut without destroying the threads. No amount of heat etc would work. I ended up using a 24-inch pipe wrench. This was apparently done to make them unserviceable and force you to purchase the entire spindle instead of just a couple of bearings. I did order the only one available in North America last summer as I was in a bind to get it repaired. At the time I repaired the second one by threading the shaft to a different size and machining a nut of the same size and inserting it into the original retainer after machining it.
I just rebuilt all three with new bearings and did what was necessary to make these spindles serviceable with grease fittings. I removed what bearing seals was required to make it work so excess grease comes out just below the pully. The new one that I bought last summer for $300 will now be a spare.
My 30-year-old John Deere 345 has greaseable spindles and have never replaced any.
