Mechanical or Work Tips
Magicman
Oct 8, 2019
5,180
6,713
Brookhaven, MS
knotholesawmill.com
I did not find a proper place to make suggestions or to post work tips that may be helpful.
Anyway, here is one that I just saw. It's a simple and handy way to measure the proper angle on a drill bit:
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
190
159
Bella Coma BC Canada
I cut a 5 gallon (20 L) plastic oil bucket in half along the long side and get two Scoop shaped halves.
Then use them to sort bolts and nuts - when done it is easy to pour the bolts/nuts back in a coffee can.
Really works well for sorting small parts like brass fittings
Hank
3,156
What angle does that produce..?
Magicman
Oct 8, 2019
5,180
6,713
Brookhaven, MS
knotholesawmill.com
The perfect angle for drill bits is 118° and 135° and this produces 120° so it is not perfect. You can see the gap between the nuts as shown.
This is simply a quick gauge if you are hand sharpening and have nothing.
