Hey guys have an issue with my machine. Been doing fine now it will turn over fine but never cranks. Getting the ENG EG code and there is no power to the little lift pump. I can jump power from the battery to the pump and tractor will crank and run fine. Looking at the FSM I don't see a fuse or relay for this so can you all help me out on where to start looking to find this problem? I have checked every fuse in the box below the key switch as well as all the slow blow fuses coming off the battery and they all check out ok. Any help would be greatly appreciated. Thanks Dale
