M6800 starts and shuts off repeatedly
1,763
That indicates that the switch is not working properly. You can test the voltage coming out of the key to the stop solenoid with a meter or a 12v light bulb in that wire. I would install the bulb where you can see it and try to start the tractor.
Even if the switch is new does not guarantee that it is working properly. You might remove it and see if you can clean the internal mechanism by some spraying method.
Good Luck!
golstho
M6800
Mar 10, 2025
17
Alabama
i tested the voltage an it was low less than 10v but that was before i repaired the wires (they had crimp connectors on them and one was loose). haven't tested again but will do so this pm and see what voltage i have. switch has not been replaced and is original, so sounds like i need to go ahead and order one.
8,337
I discovered yesterday that on the initial start that i can keep it running by keeping the starter engaged and by holding the key between start and run but at soon as the key returns to run it shuts off.
BAD switch
12251hd
M6800, L35, RTV
Nov 23, 2018
61
Woodbridge, VA
I saw an earlier posting about the oil pressure switch causing the shut off and noted that my tractor's shut off seemed to follow if the oil light did not immediately turn off. But it never shut off if the light turned off immediately. We are only talking a second or two for the light to show or not. I never had the problem when warmed up. I had concluded that switching lately to Rotello T5 vs T6 may be related to my problem. Going back to T6. Will keep an eye on switch.
golstho
M6800
Mar 10, 2025
17
Alabama
Hope the switch fixes mine but I will search for the oil pressure thread and read it. Just changed the oil in mine I used T4.
golstho
M6800
Mar 10, 2025
17
Alabama
got the switch installed yesterday and it fixed the problem. thanks everyone for all the help!
Tractor Gal
BX23D MLB
Oct 30, 2020
559
210
NC
Did you ever try a new key switch as 0007kubotaguy suggested in post #15? Seems like he would know...and worth a try.
Tractor Gal
PS Just saw that the new switch fixed the issue! Good news.
golstho
M6800
Mar 10, 2025
17
Alabama
Tractor Gal
yes he, north idaho wolfman, and russell king all said it was the switch. they were all right. switch came in yesterday. i installed it and the tractor cranks perfect.
8,337
The oil pressure switch has Zero interface with the tractor running or stopping.
It's just an indicator that the engine has oil pressure.
