Hello! I have a M6040 that has a weak loader since day one. Been back to dealer and says is fine. At low RPM the steering pulses as you turn the wheel. Tried to use the draft while using a hay king pasture renovator but wouldn't pull implement out of ground before spinning out. While using the loader with pallet forks picking up less than rated amount of weight you will have to curl down then lift as high as it will go then curl to get off the ground. When it was at the dealer they said loader cables were out of adjustment. When it returned it was worse. It is now out of warranty and I would like to try and adjust the hydraulic pressure myself. I made a test gauge adapter to fit into one of the outlets on the rear of tractor. I downloaded a manual online. If I read it correctly the adjustment is external and beside the rear outlets. The dealer said it was inside the case and had to be shimmed. Will this adjustment on the rear adjust the steering, loader, lift arms and the rear outlets? Thanks
