I'm back with this M125X yesterday, The issue this time seems to be the hydraulic pump itself. Over recent months it has developed a problem picking up prime. When first started in the morning the hydraulics don't work until the engine is revved up to nearly full throttle for twenty or thirty seconds, after which the pump starts working. It will work for the rest of the day without problem, engine stopped and started multiple times.
My first thought was something suction related. Both pumps are mounted side by side, and each have a separate suction supply from a common filter manifold. The steering/transmission pump has no problem coming to life when first started even at idle speed. The hydraulic pump, not so much. After inspecting the two different supply sides for oil leaks, obvious problems, etc, tightening hose clamps with no effect I decided to remove the seat and panels for a look at the pumps. The pump was wet, with signs of body seals leaking to some degree, so I pulled it off to install a seal kit.
The body seals were indeed hard, brittle, and in need of replacement. The wear plate seals were both actually broken as well as brittle. The gears, bearings, and housing look good, so new seals, it's back together, all lubed up and back on yesterday. It didn't pick up and go to work as I'd hoped it would. Once going, it seems to perform well enough, with no leaks. Left overnight with everything still exposed it was started again today and once again it won't prime without a few seconds of elevated RPM. I have not replaced the hose/coupler or the O ring on the filter manifold yet. Not sure if either would make much difference at this point.
Any thoughts?
Any thoughts?
