Discovered someone in it's past went gorilla on the bolts that hold the mid mount mower on my B7100. 3 bolts on each side for the front brackets to tractor frame. Most are now stripped 10mm welded nuts on the inside of a box. Near impossible to get to the back side to weld new nuts on. Did that with one of the hood bolts but it was easy to get to.
First thought is to just tap the holes out to 11mm, have the tap but discovered 11mm bolts were either made out of gold or unobtainum. 7/16 is fairly common and really close to the same size as 11mm. But then I would be committing a sacrilege against the Kubota gods.
Next option is to go to 12mm which would probably require also drilling out the holes in the brackets to clear larger bolts.
What would you do?
What would you do?
