M108S Starting Issue
BrM
M108S
Jun 18, 2019
Liberty
I recently ran into dirty fuel and had to replace fuel filters and drain tank. Ran it for 8hrs or so afterwards with no issue. A few days later, tractor died in the field while loading hay and would not re-start. Fresh oil noticed on the right side, middle of the engine and back which seems odd. Back at the barn, I checked filters again and noticed some water in the bottom of the separator. Drained water and checked fuel flow to pump which was good. Still no start. Cracked injector lines and not getting fuel that I can tell. I'm thinking I may have a fuel pump issue due to bad fuel. Any help or ideas to further troubleshoot would be much appreciated!
SidecarFlip
Banned
554
Start with the easy stuff like the lift pump which will be on the right side of the engine about halfway up. What years is it btw?
BrM
M108S
Jun 18, 2019
Liberty
It's a 2010 and do you mean the electric pump? I've replaced it several times since new and the current one is providing good flow to the main pump.
