LX2963 snowblower: Flow diverter seems stuck
Nels13
lX2610 and LX2963
Jan 1, 2024
Minnesota
Normally when I flip the toggle in my cab, the hydraulics either rotate my chute right and left or move the deflection up and down. Now either setting of the toggle switch rotates the chute left and right. This tells me that power is still getting to the chute but the flow diverter but it is not activating the directional valve. Anyone run into this? If so, what was the problem? Thanks in advance!
WAS BANNED FOR NSFW PICS
5,149
Gently tap on the flow diverter with a screwdriver handle to see if it is stuck. Your flow control valve might have an electrical problem or a hydraulic problem. Check the wiring to make sure that the contacts are clean and tight. Sometimes even just removing and replugging them will help.
Dustball
2016 B2650HSDC
Sep 15, 2023
398
251
Hudson, WI
I believe the default (no switched power) is for chute left/right operation, at least on my older blower it is. Is there power at the switch and is the switch itself working?
CAPT Seabee
Grand L5460
Dec 28, 2022
Bonners Ferry ID
If the diverter switch is left on, the solenoid will eventually burn out. The switch should be off unless in use.
Nels13
lX2610 and LX2963
Jan 1, 2024
Minnesota
I'll try this.
Nels13
lX2610 and LX2963
Jan 1, 2024
Minnesota
I'll test this. I assumed power at the switch because it moves left / right. I'll put a tester it.
Dustball
2016 B2650HSDC
Sep 15, 2023
398
251
Hudson, WI
Toggle switch off = 0 volts to the diverter (default position) = chute left/right
Toggle switch on = 12VDC to the diverter (energized position) = chute up/down
PM7788
LX3310HSDC, LA535 FEL, LX2963 Snowblower
Aug 28, 2021
MA
I know this was more than a year ago, but was this ever resolved?
I'm having issues with mine now and cant seem to figure it out. The chute rotates left and right when in the "rotate" position on the switch in the cab. when I flip the switch to "chute deflection" it still only rotates the chute and does not engage the deflection. I got deflection for a second and then back to just rotation.
LX3310 HSDC
2963 snowblower
