Hi
Could someone please confirm if drive shaft universal joint (UJ)needs lubrication or is it sealed for life. (There are rubber rings on the cross of the UJ.
Was investigating a rattle on this drive shaft and traced it to a missing oil seal part 090 on attached drawing which I can replace.
There was some emulsified oil in the bottom of housing part 010 and my query is if the universal joint is meant to be bathed in oil. I note that the upper joint on this shaft is not lubed and there is no oil fill connection on part 010.
Any comments would help before I put it all together.
Thanks
Thanks
