LP RTA1258 Tiller - Busted Seal???
mjrwood
L2501DT, MX4700,RTV400ci,Z411KW
Oct 21, 2017
60
Wellington, AL USA
I'm editing my original post as I found in the manual where it shows that the top bolt in the pic below is the breather plug.
So now my question is, should I be seeing this much oil venting? Is it normal for oil to need to vent or could it be a symptom that something else might be wrong. The reason I wonder, while the tiller is fairly new I have have used it a bit over the last year tilling garden spots. I'd never seen any oil leaking until today, when I was tilling food plots and got into some hay twine that wrapped itself around the tines. When I got down to cut out the twine I saw the oil.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
It all depends on a couple of things. If it was overfilled with oil and worked harder because of the twine, then normal. If not then I would be worried.
The vent plug is there to let off pressure to prevent blowing the seals.
I have that tiller and have never had any oil leak.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
That is nothing to worry about at all. Normal venting. Could be a touch over full, but nothing to worry about.
mjrwood
Oct 21, 2017
60
Wellington, AL USA
Great, thanks for the replies fellas. It makes sense that the twine tangling up in there made it work harder and caused the oil to vent out, it's good to have confirmation from someone who knows though. Honestly at first I didn't even realize there was a vent there, when I saw the oil leaking down I just knew I'd tore something up. :eek:
Beaudeane
MX5800, LA1065, BH92, BB72X, RT72.40, EA 60 in grapple, county line auger
Mar 9, 2018
128
Dalton, Ga
Maybe wanna check to see if it’s mixed with water? Has it been out in the rain much? The oil will float on the water and that makes the gear box over full. Same happened to me on a bush hog.
mjrwood
Oct 21, 2017
60
Wellington, AL USA
Thanks, I'll check that. In my case I want to say it seems an unlikely culprit, but I certainly can't rule it out. I do keep my implements in a pole barn and they stay pretty dry, but the tiller was on a side shed so I suppose it's possible a driving rain (we've had a few the last few months) could've gotten it soaked.
