Looking for fuel injection pump for Z750 L1500dt........
Will Nesling
Kubota L1500 DT #15392 engine Z/750 # 27874
Apr 3, 2024
Vancouver Island
Hello fellow Kubotans.......well the head gasket c/o went well, but not no much the start up! The coolant had reached the pump and plugged it ,so i took it out and cleaned it.....anyway ,instead of rolling the engine over slowly after installing pump.I cranked engine with starter.... Bang! How ,not sure. I think i rolled crank back a bit,so it slammed into rollers. I have searched the internet for this pump {#15221-51010} and i should be on Global tractors waitlist......i was wondering if any one had any ideas to find a pump or another engine..... The tractor is a "gray market' L1500DT #15392,engine is Z750 #27874.....i also wondered if this pump could be repaired........not sure if it is cast iron or cast steel...i will link picture. Thank you very much for any imput....... Will Nesling Vancouver Island
5,230
Send @007kubotaguy a message and see if he can help you out.
FYI you need a injection pump off of a L175, L185, L1500, L1501, and there may be other 2 cylinder models that match too.
Will Nesling
Apr 3, 2024
Vancouver Island
A big Thank you Wolfman and Kubota guy.........I found a Pump....thank you for recommending AG supply in Black Creek , Wisconsin........about $350. This time i i rolled engine over slowly after install..no hard spots......next c/o the hydraulic pump ,which we also bought from AG supply. Cheers,Will
