LED lights on ROP using click bond on an L3700SU
Burt
Mar 24, 2012
337
Goldendale, WA USA
Greetings Orange people,
Here is a you tube I just made regarding the installation of LED lights on a ROP using a product called Click Bond.
There are no holes in the ROP as a result.
I got this idea from another OTT guy that used u-bolts and then channel to install the same lights on his tractor. I like the idea of not penetrating the ROP metal and then found Click Bond. www.clickbond.com/
Here despite my first video ever, is the installation.
https://www.youtube.com/watch?v=7l7k3ScZxj0
Burt
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
Wow, that stuff must be very strong as there is a lot of shaking and vibration at the top of the ROPS.
If it works for you I am buying some!
I have a lot of woods and trees I work around so my lights are on the under side to avoid getting damaged or ripped off by branches.
Burt
Mar 24, 2012
337
Goldendale, WA USA
Yes, I agree that under the ROP is also a good place. So is the top, however, I found that putting them lower might catch my head in the lights and obstruct them. I powered them first to check their direction, then installed them.
Thanks for your comment.
Burt
Burt
Mar 24, 2012
337
Goldendale, WA USA
Yes, powerful strong stuff. After all, you life probably depended on it if you flew in a commercial airplane.
Check out Click Bond's site. It is primarily engineering oriented, so I suggest calling the factory to get the local rep's phone number and having a discussion with him to determine your needs.
My connectors are 1/4" studs.
Burt
Burt
Mar 24, 2012
337
Goldendale, WA USA
Quazz,
I did get a recommendation from a factory rep of a place to try to get some click bond. Here's the site: Electricalhub.com
I checked their website and they do have it.
Be sure to measure the base of what you are installing carefully and match the click bond diameter to fit prior to purchase.
Burt
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
Thanks Burt! I already checked out the Quick Bond site.
I NEED some Quick Bond! lol
5,154
Burt,
One neat trick I found that works great in tool boxes is outdoor carpeting, cuts down on rattle and keeps tools and parts from getting aluminum rubbed. I just cut the carpet to fit in one piece bottom and up all 4 sides, and use a little spray glue to hold it in place. ;)
Burt
Mar 24, 2012
337
Goldendale, WA USA
Burt,
NIW:
Thanks for the tip! I have some carpet that I'll use for that purpose. Good idea!
Burt
TxDoc
ZG227
Apr 19, 2013
40
Very nice custom lighting result. Gonna have to try some Click Bond.
Just a question, definitely not a criticism. If you mount the lights on the underside of the ROPS, so the ROPS is actually the highest point, would the lights/wires have better protection from limbs and obstacles. Or will that position have the lights too low for the proper effect?
( Bear in mind, I am asking this while I have a 40 inch LED light bar on top of a roof of a Yamaha Rhino. I just have to be careful!)
Good work, good result! :)
on edit-work in the shop always goes better with your dog napping alongside :)
Wildfire
Click Bond is a great product. A company rep gave me two boxes of it last year to try and I was hooked. I've used it in many applications including the BX and 5740 Grand L. I used it to install the 3rd function hoses on the BX and also to mount a fire extinguisher on the ROPS of the BX.
http://youtu.be/v7aYYuWIh_8
2,842
I see things must be slowing up a tad in the shop, yeah like that ever happens huh,,lol,, good to see you popping in again my friend:D
Wildfire
Oh man. You should see it outside this morning. The lot is full. It's going to be a loooong day. Just take note of the time I replied to this thread in my first post.
Keep well buddy.
Burt
Mar 24, 2012
337
Goldendale, WA USA
Quazz,
I just found this short you tube video on Click Bond...a Hammer test! Check it out if you don't think this stuff is strong!
Plus, I notice some other OTT contributors found some other sources for Click Bond.
https://www.youtube.com/watch?feature=player_embedded&v=EfHAccRW0PQ
Burt
