Landpride 1260 blade nut
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
256
Poplarville, MS
Anyone got any idea of the nut size on the blades of this rotary cutter?
I want to take the blades off at some point to balance.
It's a big ole nut !!!
Thanks, Pete
mickeyd
Mar 21, 2014
1,192
Guin, AL
The nut for that bolt is 1-1/8".
If you go to LP's site, you can download: Manual No. 318-000M, "Rotary Cutter Blade Bolt Kit" which has all the specifications.
Blondie70
Aug 6, 2016
256
Poplarville, MS
LandPride 1260 blade swap
I am tired of being covered in dirt from my lift blades on the mower. I am gonna swap out for some with no or little lift. I have the 5' cutter.
Has anyone done this?
If so, what blades did you use and how are they working ?
Thanks, Pete:confused:
CapnDean
L6060,ZD1211
Feb 22, 2018
184
Gulfport, MS USA
Re: LandPride 1260 blade swap
I have the 2572 rear discharge - never a problem. I have a new set of blades for it too. Since yo're so close...come borrow mine and see if it does better before you go swapping stuff around. Can you swing a 6' finish mower?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,158
949
Williamstown Ontario Canada
If you are not familiar with torque multipliers look at this link and then watch some you tube videos. Unless you have a serious impact gun getting these large fasteners to let go can be a challenge.
https://www.youtube.com/watch?v=RzZS8x-rNuY
https://www.amazon.com/Tenive-Tool-...23406&sr=8-5&keywords=torque+multipliers+tool.
There is a wide range of styles and prices. The one I provided the link to does not have the socket you need but any one inch drive impact socket will work.
Amazing increase of torque with simple internal gearing. The youtube video product produces almost 3,000 lb ft of torque
Dave
Blondie70
Aug 6, 2016
256
Poplarville, MS
Thanks, Cap'n. My turf is a bit ruff for a finish mower. I would be afraid of tearing one up.
My brother is in the market for a used finish mower in Saucier. Wants a 5'.
Know of any for sale ?
Thanks, Pete:D
Blondie70
Aug 6, 2016
256
Poplarville, MS
Thank you for the torque multiplier info. Gonna try it with a few tools I have around here first. See what happens ...ha.
That nut appears to be a 1 11/16" size for a 1 1/8" bolt. Got a socket ordered. Since the thing is fairly new, hoping it will just pop rite off ...haha ha ha ha
We will see.
Thanks, Pete:D
Camlocker75
L3830, L3901, JD 5103
Dec 30, 2015
31
Alabama
Best bet to get those nuts off.....
1. Go to Tractor Supply and get a 18 inch 3/4 breaker bar, 8 inch extension, and 1 11/16 socket, 4 foot cheater pipe
2. Acetylene torch - get bolt cherry red
3. Use cheater + breaker bar to pop them loose.
Used this method to get them off my RCR2560.....now that was fun!
mickeyd
Mar 21, 2014
1,192
Guin, AL
We will see.
Thanks, Pete:D
I used my portable impact driver on mine and it works very well.
I know what you mean about the dust, that is why I try to do mine right after it rains.
In fact, if it isn't raining very hard, I will do it then.
Blondie70
Aug 6, 2016
256
Poplarville, MS
I have my cloud of dust problem fixed with my LP 1260. I put some "normal" blades on it and took the airplane propellers off. Cuts great, no cloud of dirt all the time all is good now.:D
mickeyd
Mar 21, 2014
1,192
Guin, AL
What blades did you use and what did you use on the bolts?
Blondie70
Aug 6, 2016
256
Poplarville, MS
On the above post, note that the blades I put on are 24 1/2" long. The super high lift blades on the LP 1260 listed as 25".
I lost no cutting width as the extra 1/2" on the LP is behind the mounting hole and is just wasted metal. The actual blade from the mounting bolt is exactly the same length as the original.
Getting the blades off is easy. I used the above socket with a 3" extention and a slide type breaker bar. Stuck a cheater bar on it and off they came. All the above tools are 3/4" drive...1/2" ain't gonna cut it.:D
