Does the LA844 have a 2-stage "fast dump", where you have 2 detents in the rightward direction on the joystick? Is that what's meant in the specs where it says "regenerative bucket dump"?
I compared the LA844 specs to Bush Hog's Quicke 180C loader, which I found is compatible with my tractor (MX5100). It appears to be a little stronger overall, with slightly bigger cylinders and greater lift capacity and bucket roll forces. However, I was quoted over $1000 higher for it, and I'd rather stick with Kubota I think. Thoughts?
