LA302-1 FEL bucket cylinder fittings
aauclair56
Kubota B7510 with LA302 Loader and RCK54-24B mower
Jun 4, 2024
Vermont
I noticed some fluid coming from my bucket cylinder upper fitting. It looks like an ORB style fitting. Has anyone serviced these fittings before. I am wondering if the Oring is damaged. Can the fitting be repaired easily?
8,284
On the older model cylinder, that's just a plug and seal (upper pic).
But on the newer cylinders they don't show it, it could be a plug or could be a banjo bolt. (lower pic)
Pull it and see which it is.
If a plug new seal and pipe thread dope will seal it up.
If it's a banjo bolt new seals and tighten.
aauclair56
Jun 4, 2024
Vermont
finally took it apart. It is just a plug 3/8-24 with an Oring to seal it. The fitting must be welded on.
4,826
