L48, Hydraulic brush cutter
garryr
Bobcat S185, L48TLB, L3010HST, Ford 5000
Oct 11, 2016
10
South Texas
Hello, I have a 2004 L48 TLB with a hydraulic remote on the front loader, will this setup handle a low flow 48 to 60 inch hydraulic brush cutter. Thanks Garry
5,312
No, not at all.
You need a high flow setup to run any kind of high capacity motor.
Your front remote is designed to run a hydraulic cylinder not a motor load. ;)
garryr
Oct 11, 2016
10
South Texas
They make some low flow hydraulic brush cutter that require 8 to 16 gpm. Will those also not work? This would be used on the farm mainly to clear white brush on the roads at the farm. It would not be cutting anything heavy. Thank You Garry
