L4701 Coolant level drop after servicing
Tom46
Kubota L4701
Jan 4, 2024
22
11
Iowa
Hello All, I appreciate all the advice I have received since joining this group.
I drained my radiator and reservoir. Topped off radiator and reservoir. Ran engine ten minutes and there was no change in level. Operated the machine for two hours. Level went from high mark to below the low mark, almost empty, on the reservoir. Just checking if this is normal? Thanks
William1
BX25D
Jul 28, 2015
1,093
279
Richmond, Virginia
Probably. Just burped/purged air. I find that sometimes I have to top off the recovery tank a few times before it stays steady. Run, get hot, let cool, air is purged and coolant drawn in. Level drops.
2,121
+1.....I dislike (AKA F'ing hate...)working on cooling systems because of this phenomena......(I use the "F" word because if you are unfamiliar with the particular system, it ranges from "ooooo boy, some coolant spilled out.............all the way to .........."HOLY FU&K , that thing is overheating!!!"
I use a "vacuum filler" to avoid this problem.
There may be some sort of system that these vacuum fillers do not work for, but I have not found one yet.
150 bucks......Worth it, IMHO.
Edit: https://www.amazon.com/gp/product/B0002SRH5G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
3,198
I ran into this with my RTV-X900… I thought I‘d done the job properly…. then it overheated almost immediately…… I shut it down….. THEN I found there was in the Owner’s Manual an “engine coolant breather” (located behind the drivers seat, between cab and dump-bed.) when re-filling the system. I don’t think this is intuitive for most owners. (I recall my days as a Toyota-tech in the early ‘70s there were instructs to open various devices in cooling systems in order to avoid air-pockets that will fool-with sensors and thermostats and also will prevent completely filling the systems. )
Tom46
Kubota L4701
Jan 4, 2024
22
11
Iowa
Thanks for the replies. This has been a learning experience.
