L4310 Sight Glass Leaking
Justacafe
L4310
Apr 5, 2014
14
Madison, wi
From what I've read, apparently this is not an unusual problem. Does anyone know how to repair/replace the sight glass, or how to deal with this problem? Thanks in advance!
2,292
Not sure about how your site glass "sits" against the gasket. Have you looked at the gasket that seals the two pieces and look for places that are not making good contact? I do know from the old ford N series days that over tightening the bowl was a major no-no. Does the bowl "spin" or must it sit a certain way? On the old N's you could work that glass bowl slightly as you tightened it and stop the leaking fuel.
5,512
Justacafe,
Are you talking the sight glass in the hydraulic fluid that's located in the rear end?
It's just held in by a lip and some silicone.
85Hokie, I think your talking about the old fuel bowls, completely different monster than the sight glass for the transmission. ;)
2,292
Justacafe,
I was Wolfman, I was........
a monster.....ol' leaking sum beeauch monster! :D
thanks!
Justacafe
L4310
Apr 5, 2014
14
Madison, wi
Yes.....the sight glass in the hydraulic fluid that's located in the rear end. Can it be re-sealed? Does it require replacement? Is this something easy to replace? Thanks for the help!
5,512
If it's leaking, It's best just to replace it with a new one.
P/N 31301-14230
http://www.goldeneagledirect.com/index.php?l=product_detail&p=95632
Just drain the fluid down below the glass, plus a little more, then pull it out, it's like a plug, clean the hole with some brake parts cleaner, then install a new glass and rubber with a little automotive silicone around the edge, Use one of the Ultra silicone like a ultra black or ultra blue.
