Hello,
I have discovered that my brake discs are failing and clogging my hydraulics. I have begun to replace the brakes.
I have removed the brake case from the left side with no issues. However, in looking at the right side, the differential lock lever is in the way of the removal.
Can anyone tell me what I need to do? Do I need to remove the two spring pins? Or can I remove the whole assembly by removing the two nuts holding it to the rear end? I would prefer to remove as an assembly but I am worried about the internals. I do have a WSM, but it is not clear on this.
I was wondering if anyone else had done this procedure on this tractor and how they may have done it.
Thanks in advance for any thoughts or tips.
Greg
Greg
