L3250 clutch peddle question
Clint.In.Trees
L3250D
Dec 10, 2016
14
Huntsville, Utah
Hi all. I hope your kubotas are running fine.
My l3250 is doing alright however I was under it today and noticed a bolt was loose. After I got a protective pice of sheet metal off of it I found something that I didn't recognize. Can anyone educate me on what is going on here? I tightened the bolt that I am pointing to.
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
X2 on travel stop, perhaps missing a rubber bumper? I didn't see either on the parts diagram though.
5,326
Well that would be where the clutch neutral safety switch is supposed to be attached. :rolleyes:
Let me guess it starts in gear. :eek:
4,469
If you're going to keep it without the safety switch the bracket serves no purpose.
To be safe for others, at least, buy the switch, wire it up, and adjust the bracket as needed. Sure beats running over someone, or through a wall!
1,021
What they are trying to say is that you are missing a plunger type switch that screws into the hole in the top (stationary) bracket and the clutch pedal will activate the switch unless it is pushed down.
