L3240 pedal sensor
Northern Maine
11
PRENTISS TWP
So my l3240 starts up and runs fine, everything works as it should. But after it's started I press the HST pedal and the tractor dies, but if I rock the pedal it will catch before tractor completely shuts off? I'm thinking it's the pedal sensor that's bad? Anyone had this issue? Thanks for any and all information.
2,183
I agree with Chim - that seat sensor can be a sumbeach if not working correctly. Lift seat up and look at the sensor(s) - place a piece of tape over in a temporary fix kinda way and then see if it makes a difference. IF so - then an adjustment might be in the works. Any weight forward will trip the sensor. OR someone who is very "light" in the seat of the pants:D;)
5,163
Some of the seat switches are built into the seat, they get depressed when weight is applied to the cushion, to bypass that kind of switch just make a jumper wire, and see if your problem goes away, if it does then the switch will need replaced or adjusted. ;)
Northern Maine
11
PRENTISS TWP
I've already bypassed the seat sensor. I was moving snow with the tractor when it started to act up. Seems to only do it during the winter. It did it once last winter, I removed the pedal sensor took it inside for a few days then put back on it worked fine until a week ago. I'm thinking the pedal sensor is bad. Tractor has around 3000 hrs on it.
Northern Maine
11
PRENTISS TWP
Ok so I replaced the pedal sensor and still not working. Dealer said it's a safety switch issue. Anyone had this type of problem with there tractor. Mine is a 08 L3240 hst everything works as it should. But when I hit the pedal to move the tractor it dies. I'm 2 hrs from the dealership so really hoping to fix this at home
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,115
Hardisty, Alberta
Did you bypass the right seat switch? There are two. One is the seat tilt switch which allows the pto to operate when you are not in the tractor if you have tilted the seat forward. that switch will not allow the tractor to move. the other switch tells the OPC if you are in the seat. only when it is satisfied will the tractor move.
eserv
May 27, 2009
2,115
Hardisty, Alberta
Inspect those wires behind the seat! That is usually where the problem is. They flex every time the seat moves up and down so eventually fail!
