L3130 front axel
Proot
L3130
Dec 18, 2020
Va
Seal leaked. I drove tractor and it ground the axel and the wheel fell off. Now I have to replace the flange,axel and bearings
Did a bad seal and oil drained out cause the bearing and axel to fail or do i have another problem. I didn’t drive more then 1/2 mile with low gear oil
66vette
20
Greenville, Ohio
I had the same thing happen to my L3130, bought a used L3130 forgot to check front axle fluid, drove about 1/2 mile and the wheel fell off same as yours. Replaced everything by Kubota service center and everything fine now.
Proot
L3130
Dec 18, 2020
Va
Do you know what they replaced?
200mph
Mar 3, 2017
1,228
61
PA
Seal might have leaked because the bearing was going bad, causing the axle and seal to no longer be coaxially aligned.
Curious how much ballast you use with the loader. It's very easy to overload the front axles without a significant amount of weight hanging off the back. This can be exaggerated if your machine has the 700 series FEL vs the smaller 500 series.
66vette
20
Greenville, Ohio
I tried to attach the file also copy the file and list it below but the site would not let me do that. There are 25 items they replaced.
old and tired
L2800 HST; 2005; R4
Is one of these files the correct one?
