G garrettohio New member Equipment Kubota L2900 Sep 16, 2023 27 0 1 Ohio Apr 27, 2024 #1 It didn't do that with the injectors in it.now blue smoking alot and didn't fix the knocking.only thing I noticed different is motor not pinging.
D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 13,068 4,427 113 40 miles south of Kansas City Apr 27, 2024 #2 Perhaps you have low quality replacement injectors?
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,402 2,202 113 Bedford - VA Apr 27, 2024 #3 garrettohio said: It didn't do that with the injectors in it.now blue smoking alot and didn't fix the knocking.only thing I noticed different is motor not pinging. Click to expand... white smoke typically is unburned diesel fuel - blue smoke is burned engine oil, worn valves seats, worn rings..... Where you get your injectors from? And describe a knocking ....... that in itself is a whole different problem - and describe the pinging too.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,864 5,223 113 Sandpoint, ID Apr 27, 2024 #4 I've made the comment twice that the injectors that you got are very likely not good. Find a local fuel injection shop to test them. OR better option: Find a local fuel injection shop to rebuild yours or send them here: Home Oregon Fuel Injection specializes in the repair of diesel fuel injection systems, replacement diesel parts, performance parts, drive-in service, repairs and diagnostics. oregonfuelinjection.com It's really sounding like you have broken rings or a broken piston. A compression test will tell you instantly.
