L2850 V1702 di > V2203 di conversion
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
Here is the near complete project just installing the loader with help from the B2150.
Wild and Free
Oct 25, 2012
390
North Dakota
Thanks Darrell.
Not sure if I mentioned it or not but since the new engine had no predrilled port for the mechanical fuel transfer pump and I didn't feel like trying to drill out a hole that big in the boss of the block I opted for an electric fuel transfer pump from Napa. You can see it in the video. I mounted it to an existing bolt hole on top of the intake manifold and it works awesome. Used a fuse tap and spaded into the shutdown solenoid fuse which is hot when the key is turned on and located behind the radiator so only needed about a foot of wire to power it up. It was relocated a bit from what is seen in the video during the wiring and hose reroute to refine and clean up the look a bit just forgot to take a finished pic of it after the fact.
5,118
Do you think if your tractor would have been a d1703 it would of been hard to swap...
Sent from my XT1254 using Tapatalk
Yes it would be hard as the V2203 is a whole piston length longer.
