Also I found a great gear shop here in Dayton Ohio that is making a new propeller shaft with splines and hardening the ends. It’s called Trojon Gear. Great group of guys and passionate about doing jobs just like this one.I found a readily available coupler that has the correct spline, length, and OD. The only difference is the roll pin size which can be redrilled 90 degrees away if I can’t make the larger roll pin work. P/N 3A021-44520 Output Shaft Coupler Fits Kubota L48 M4700DT M4800SUD-F M4900DT - happens to match the L275 as well beside the roll pin hole diameter.
Hopefully this helps someone else in the future.
