L2501 Turbo: A Journey Defined - The tractor, The comparison, The modification, The results...
miker2702
b7500 and l2501 farmall cub powerking and 8n
Aug 4, 2025
11
east tenessee
Indeed it does! The factory pump provides more than enough fuel for the Turbo Kit.
However, OEM components do fail, especially on older/high hour tractors. One of our customers has had to replace his faulty lift pump on an L3240 tractor. Definitely something to keep in mind.
Mike
just at hundred hours.....
Rdrcr
Vendor Member
May 7, 2021
742
901
WA
One hundred hours is nothing for one of these tractors.
Mike
Rdrcr
Vendor Member
May 7, 2021
742
901
WA
I'm confused. Have you seen many lift pump failures at 100 hrs?
We have a lot of S2T Turbocharged L2501 tractors with well over 100 hrs and zero problems.
Mike
miker2702
Aug 4, 2025
11
east tenessee
Mike
it was the issue i had changed fuel cleaned tank and new fuel filter. the amount of difference between the old pump and new pump by just pushing plunger was alot...ive read where these are prone to fail causing sputtering and loss of power...ive had a bx and a b now a l so my first experience with a l ...i just thought you guys modifying these might have came across a bad one or one that would not provide enough fuel..
when it fails it will not get enough fuel to be able to the bleeder to get air out.
Trash Panda
L2501
Feb 18, 2022
82
62
Wyoming
The OEM pump isn’t exactly a high flow unit, but it doesn’t take a lot of diesel to make 40hp.
miker2702
Aug 4, 2025
11
east tenessee
guess not im fixed it seems so im relieved not anything else. maybe the turbo in my future need to sell some junk raise funds. thanks.
Rdrcr
Vendor Member
May 7, 2021
742
901
WA
I was recently contacted by a local Kubota owner with an LX2610 Cab that wants a Turbo Kit. So it looks like we'll probably have a couple new Turbo Kits for 2026!
Mike
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
177
102
Ellicott City, MD
Mike
Mike,
I'm now at nearly 50 hours on my '25 LX2620. For purposes of the turbo kit, I presume the LX2610 & LX2620 are identical?
Andreas
Rdrcr
Vendor Member
May 7, 2021
742
901
WA
Mike,
Andreas
We need to do more research on the LX engine and platform before we get started but, I believe so. Our goal would be one Turbo Kit that would fit both the LX2610 & LX2620. The LX customer is very, very excited. He's already come by on multiple occasions since we initially talked about the Turbo Kit. Right now we're just getting things scheduled. We have the Kioti CK2610 / CK2620 - Bobcat CT2025 to Turbo first, then we'll get going on the LX.
We're heading into our busy season, so we will be dedicated to getting those Turbo Kit orders filled before we begin the development on the future Turbo Kits. That said, we will have the Kioti/Bobcat tractor soon and the LX tractor is available to us at anytime to begin the process.
Mike
AOW162435
Jun 16, 2023
177
102
Ellicott City, MD
Mike
Mike,
Great, thank you.
Andreas
