L2501 tire question
Maxl
10
I want to change the front tire size from 27x8.50x15 to 27x10.50x15 would I need to change to a wider rim, would the extra width be to much stress on the front end? The ground I'm working on is a little wet the extra floatasion would be helpful.
Thanks, Maxl
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
428
35
Red Springs, NC
I plan to do the same when mine need replacing. I looked up the part numbers of the wheels [27x8.5]for the basic L series and the 27x10.5s are stock on a TLB 35 if I remember right and the wheels had the same part numbers from what I found.
2,202
Thanks, Maxl
Not at all, however - I would check the rolling circumference, but based on the other poster, seems it is offered on the HOE model so that will not be a problem;)
troverman
Jun 9, 2015
1,188
268
NH
I agree - no harm to the machine by adding a little width. But I would also check overall diameter of the old and new tires. If they are different, using 4x4 forces the fronts to slip and puts a lot of stress on the drivetrain.
Grateful11
86
Piedmont, NC
Thanks, Maxl
I did a little checking into this and it appears the rolling circumference of a 27x8.50-15 is 79" and the diameter is 26.6" and the rolling circumference of a 27x10.50-15 is 79.5" and the diameter is 26.9". Not sure if this is enough to cause harm or not. I suspect if there's a fair amount wear on the rears it would compound the problem. These are all measurements from BKT Skid Power HD Skid Steer Tires.
https://www.petestirestore.com/27x850-15-BKT-Skid-Power-HD-skid-steer-tire-8-Ply-TL_p_6755.html
https://www.petestirestore.com/27x1050-15-BKT-Skid-Power-HD-Skid-Steer-Tire-8-Ply-TL_p_6028.html
JNb
L3000DT
Dec 1, 2018
11
New brunswick
I would look at the bkt website for tire specs if you are interested in the rolling circumfrence, I have noticed that the specs for bkt tires on the petes tire store website don't match what the bkt website has.
