L245dt meter cable
L245dtRCA
L245dt, box scraper, 6 way blade, FEL, 4'Howse rotary mower
Jul 18, 2018
Molalla, Oregon
I saw that my hour meter stopped running recently, so I disconnected the cable...its broken somewhere in the middle, so I needed to replace it
the parts list shows 2 parts:
37220-34650
35240-34650
I ordered a cable from Walmart, it is a bit long, but it fit on the engine end, however the fitting for the meter end didn't work.
I didn't carefully check the number and ended up with a 34260- 34650
the threading for the meter end was on the outside of the fitting, rather than internal...but how do I know which of the 2 parts listed above to replace it with?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,144
940
Williamstown Ontario Canada
Armed with your tractor's serial number, call Messicks.
Parts Hotline : 877.260.3528
Likely there is a serial number where the parts changed from one to the other number.
Dave
5,318
I do believe it should, if you have the old cable post up a couple pic's of the ends.
And someone with one should be able to confirm this.
