I have a L-4400 and the FEL lifting capacity seem low when I purchase my tractor used. So, I did a little research and found on Tractorbynet.com, a forum on how to increase the Hydraulic pressure setting by replacing the manufacture washers with a larger one and checking your pressure increase by placing a psi guage on your FEL quick coupler located above the control handle. It was simple and I increased the psi from 2495 psi to 2630 psi. This setting was base on the manufactor's max. setting psi for this model. I bought a quick coupler fitting at the dealer and asked what the max setting was for my Hyd. relief system, went to the the local hardware store and bought a 5 cent flat washer about the size of a dime. I remove the plug in the relief valve block and replaced two thin washers with the one I purchased and the setting was just right. Remember that I set my psi to whatever the max. operating psi was set by the manufacter and do not exceed that setting. I have been operating my orange BeBe for some time now with this setting and feel very please with the way it operates now, alot more lifting capacity. On that web site they had picture and detail instructions on how to increase the psi. It has worked for me and others that are satified, hope that this has helped answer your problem.
