When I pulled off the control panel to replace the steering box I found some burned wires and rubbed through wires. It's the glow plug wires of course are burned and some others, might have been head light wires.
Since I switched over to a GM 12SI alternator I don't need most of the 6 wires that went to the voltage regulator. There are other dead end wires and plugs under the dash too that can go.
I also replaced the almost useless 35w original headlight bulbs with 100w H3 bulbs, so the original headlight circuit is useless now that I'm running about 3 times the amps on it.
