Kubota z122r no spark
Kevraider33
Kubota z122r
Mar 23, 2025
Oklahoma
Z122r zero spark would not crank with the key switch But wood arcing The solenoid. All safety features engaged, battery charged went ahead and did my spring tune up new spark plugs oil filter oil air filter fuel filter fuel. Replaced all the fuses as well as the 30 amp over near the battery. Still no crank. Replaced key switch and starter solenoid still no crank but if I Arc the solenoid it'll crank but no fire no spark
1,598
It sounds like a positve power wire to key switch to starter problem. Make sure there is 12 volts to the switch and that there is 12 volts at the crank position when you turn the key to crank.
Since the starter will crank you eliminated that as a problem. See if you are getting 12 volts to the end of the small wire on the starter solenoid when key is in crank position. Probably not working properly.
I think the zero turn mowers have a ton of safety switches on them but I don’t know exactly where they are. Probably seat, control arms, brake…other stuff. I think you should try to find them and see if they are working properly and passing the power through to the next component (starter, relay, computer…)
7,977
You need the WSM (aka service manual) so you have the wiring diagram for it.
It will also have information on how to troubleshoot it.
7,977
This the best I can do on the WSM
You more than likely have an issue with the starter relay or switches, fuses, or controls that control it.
Unlike a tractor the starter relay on your unit not only controls the ability for the starter to be engaged but it controls the spark output from the magneto.
And note the starter relay doesn't actually engage the starter, it just make it possible for it to happen.
5,372
2,057
brake switch is the usual issue of a no-crank complaint. Test it, or just replace it. May be an updated part number now.
