Kubota virgin part 2
Shauney22
Kubota B8200 HST
Jun 29, 2013
29
Summerstown Ontario
Alrighty, I've changed the oil and filter, I tried to shut off the valve for the fuel filter, but it kept flowing. Closed the valve, and then bled the fuel lines. I've cleaned the air filter, even washed it. I have the battery charging and cannot seem to get the tractor to turn over. I took a video but am having a difficult time uploading it.
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
334
Alberta
Make sure the battery connections are clean and tight. Are you sure the battery is in good shape? Also put the trans and pto both in neutral and fully depress the clutch when you try to crank it over. Do any lights illuminate on the dash when you turn the key to "on"? Have you seen this tractor run?
Shauney22
Kubota B8200 HST
Jun 29, 2013
29
Summerstown Ontario
Yes, the tractor was running last week, just always a lot of very black smoke coming from the stack. The lights illuminate and the battery is properly connected. It ALMOST turns over but then it just goes right back to trying. I have a video but can't upload here.
2,860
Man your havin one hell of a day,, time to get a cold one and contstapate on dis
freewheel3
Mar 9, 2013
334
Alberta
"It ALMOST turns over but then it just goes right back to trying."
Im not sure we're speaking the same language here. Does the engine rotate or not when you turn the key?
"Turn over" generally means the engine will rotate.
"Fire" generally means the engine is trying to start, usually will be some type of smoke and the occasional popping sound out of the exhaust.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
If I understand you correctly you washed the air filter. If so before you do anything else replace you filter with a new one. Paper filters don't like water. Lets get that taken care of and we'll go from there.
5,258
I'll second the new filter!;)
Also when you bleed the lines you need to have the fuel on not off?:confused:
Are you giving it 30 sec or more of preheat on the glow plugs?
Have you checked to make sure the glow plugs are working?
What color smoke is coming out the stack when your trying to start it?
Is there a significant amount of smoke coming out the breather tube?
Shauney22
Kubota B8200 HST
Jun 29, 2013
29
Summerstown Ontario
Well, right about now, I'm thinking of throwing in the wrench! Yes, the engine "turns over" and "fires" but just doesn't quite succeed in turning on. I saw Vic's video on the air filter, and did wash it. The glow plug (singular) is working but no, I did not give it 30 seconds. I have no idea what a breather stack is (blushing at my ignorance). Smoke is grey, no longer black.
Two things that I have learned from this experience so far:
1. Always have the right tools for the job and
2. Never wear an exposed belly piercing while working on a tractor. Diesel, oil and blood... it's not a pretty sight!
Okay, I believe I did mention that this is ALL very new to me!!!! :)
5,258
Excellent to here you got it running!!!;)
Hope you recover from your injury quickly!:p
(I never would have thought I would put that injury on my "read it on OTT" list):eek:
