Kubota u17 wont shut off with key after new fuel stop solenoid
DirtShapes
Kubota u17
Jun 26, 2024
Hey all, new here. Hoping someone could shed some light on my problem.
Ive got a 2022 u17 with just 275 hrs. It quit while running and wouldn't start back up. realized it was blowing the 30amp "engine stop" fuse. Unplugged the fuel stop solenoid on the pump and it quit blowing fuses so i ordered a new solenoid. Got the new solenoid installed today and it started right up, but will no longer shut off with the key, i've got to use the lever on the pump to shut it down. It actaully seems to idle up a little bit when i turn the key off. Is there another relay or module that controls that solenoid?
Thanks!
DirtShapes
Kubota u17
Jun 26, 2024
So I did get mine working. The first shutoff solenoid I got from the dealer was also bad, just stuck open instead of stuck closed seemed like. I ended up buying another solenoid online and put that in and it’s been working fine ever since.
Hey! Same situation here. Did you find why you were not able to shut it off with the key?
Thank you!
