Kubota L185
5,333
Yes that is the same part # for your L185 / Z751
Sim, é o mesmo número de peça do seu L185 / Z751
vitormotor
kubota L185
Sep 19, 2010
36
portugal
Comprei um cabeça para o kubota L185
Já tinha as válvulas instaladas
Tem uma diferença
A parte que leva a capa valve
É mais alta
vitormotor
kubota L185
Sep 19, 2010
36
portugal
bought a head for the kubota L185 I already had the valves installed. there is a difference The part that takes the valve cap is higher
5,333
Picture of it please.
It may be remade where it doesn't take the cap?
1,022
Please explain how you repaired the problem.
Por favor, explique cómo reparó el problema.
5,333
Russell, you're close, he speaks Portuguese not Spanish.
Por favor, explique como você corrigiu o problema.
1,022
Sorry I guess I copied the wrong translation since my Spanish is weak and Portuguese is non existent (other than I can tell it is not Spanish)
5,333
No sorry needed, It was just slightly off.
It's cool that we all can help others from all over the world!
vitormotor
kubota L185
Sep 19, 2010
36
portugal
Tinha uma batida nas válvulas
Depois de análisar foi visto que o problema era afino de válvulas
0.18mm admissão 0.22mm escape
Agradeço ajuda
MOD Translation:
Had a knock on the valves
After analyzing it, it was seen that the problem was valve tuning
0.18mm intake 0.22mm exhaust
thank you for help
