Kubota b7100 4x4 Whats with this?
BigRod
Kubota b7100 4x4 4' KingKutter tiller
May 22, 2024
Raytown, Mo.
Doing a standard clutch repair is no issue until I find it has a DH850B "455cc" engine so the issue im having is locating a pilot bearing very limited information not knowing what equipment it was installed originally. Any help please.
4,628
Might call Coleman Equipment in Lee's Summit, 816-491-eight eight nine six. Should be setting right there!
Mountainman
L2501, B7100, B6000, BX24, B1750, B2400
Jul 10, 2022
145
50
Attalla Alabama
mossycreekoutdoors.com
Is the bushing to small for the hole? Some wear out and the shaft wobbling around in there will make the hole larger in which you'll have to have a machine shop make you one or replace flywheel. I have several flywheels if you need one
5,476
The pilot bushing doesn't seat in the flywheel on these engines, it seats in the back of the crank. ;)
Worn pilot bushing hole is really difficult and costly to fix properly. 😟
I've done a couple that I've used a boring bar rig on a running engine to over cut the hole larger and use a custom bushing, not a fun repair.
Mountainman
Jul 10, 2022
145
50
Attalla Alabama
I stand corrected. Sorry long day. Thank you @North Idaho Wolfman for correcting me
