Kubota 1880BX cutting dial won't lower
MarkWP
Bx1880
Apr 15, 2024
Wills Ooint
I'm VERY new to tractors, a complete novice. I was able to raise the cutting dial to 4. Now I can't lower it.
I know you have to lift the deck, the knob only turns clockwise. But, when the messages I read say do this or that, I have to research that information.
Can someone direct me to a video or give me steps and tricks to get it lowered again?
TIA
Mark
4,116
Mark - -
Just need to raise it enough to take weight off the height adjustment mechanism.
Use your control level to raise the deck until you can just hear the hydraulics go into relief. You'll hear a change in the sound when it hits top. Release lever and allow it to go to center again.
Now you should be able to turn the adjustment knob.
Good luck.
Bearcatrp
BX1880
Mar 28, 2023
407
204
Minnesota
RCW is right. Did it to me on my 1880. I just raise all the way up. The 3 point I noticed goes up all the way first, then the deck. Might have to play around with the knob a little. Let us know how it goes.
