Is this the correct plan for adding a slide valve?
4,432
Thank you for your patience in providing so much information, but for a novice who is in contact with hydraulics for the first time, these terms are too professional. I have no idea at all. OK, I have now checked the approximate appearance of the product corresponding to each digital term, and plan to use the most primitive method, remove the Kubota hose that needs to be replaced, and take my valve body to the store to compare them one by one.
What I need to do is,
Remove the green hose from the loader valve and connect it to the valve through a suitable adapter,
Buy another hose to connect the valve and the loader green interface,
The last hose connects the T of the valve and the T port of the block. Since there is already a hose for the loader valve on the T port, a suitable tee is needed
Good plan.
The documentation on the new valve should tell you port types and sizes. Given your global location my first guess would be BSPP.
In North America Kubota hoses are typically JIC swivels but given your spot on the globe yours may well be BSPP.
Whatever the thread type you will probably want something like this BSPP to BSPP male union for the hose connections to the new valve.
sumking
kubota L2502-526, RTR1250tiller, sgc0660 grapple, Box Scraper, Landscape Rake,
Nov 4, 2023
canada
Good plan.
Dear DAN, could you please check the previous post regarding my question about the snow blower?:ROFLMAO: thank you
4,432
I dont know the details of the chute rotation motor but your hydraulic flow is probably more than needed and you are likely to find the chute rotates too fast.
