I recently picked up a 1985 B8200HST DT that came with a loader and front mounted snow blower with hydraulic lift. I recently did all the fluids on the tractor and have a leak on a rear line that I'm assuming was used for the snow blower but can't find much info on it. Attached are photos of the fitting/adapter (circled in red). There are two long lines attached to it that are connected together under the tractor with a quick coupler. It appears to be connected between the hydraulic block that powers the loader/steering and the hydraulic control valve for the rear 3 point hitch.
There is mention of a rear remote setup for this tractor in the WSM but it doesn't show anything about this fitting. Also can't find it in any of the parts diagrams that I have or are on Messicks. Curious if anyone has any info about this. I'm actually concerned it's throwing off the 3 point because when I lower the loader, the rear implement also drops if I don't have the implement "locked" up with the implement speed control knob all the way tight. Maybe thats normal with a loader and 3pt on this model, I don't know.
If this is a normal setup, is there any reason I can't take the valve used for the lift cylinder of the blower and mount on the rear of the tractor to use for a rear top link or other accessories?
Attached are some photos of the adapter and the valve that came with the tractor for the blower.
Ironically the WSM does speak of an optional rear control valve that connects to two ports (I believe what I have circled in blue) on the top of the main control valve for the 3pt hitch. I'd assume these are lower pressure but is there any reason not to tap in there vs this weird adapter my tractor came with?
