IR impact wrench not working
luc.who
Lewisberry PA
Looking for any help here, I have an IR 1/2 impact. While I was doing brakes on an older car today, bolt was too tight, so i got out my impact wrench. It broke the first bolt free no issues, (PB blaster soaked...) and when i went to remove the 2nd bolt the wrench just blows air.
Any thoughts on what the issue could be?
4,825
Try switching between forward and reverse. Your switcher could be popping in between and getting stuck. Before I had my snap on gun rebuilt the valve would move very easily and pop halfway between the two positions. I had to hold my finger on the button when using the gun to keep it in position.
My snap on gun quit working. Mine ended up being a snapped anvil. A chunk had broken off and was locking up the unit.
Sent from my SM-G920V using Tapatalk
2,923
Make sure you are using air oil, one time I used what ever oil was laying around. I wound up taking the impact apart it was all gummed up,,, soaked everything cleaned it and lubed with air oil,, worked fine after that
bernhardine
M4072 (M4D-071), B7000
Jan 14, 2019
77
Germany
What temperature did you have at that time? and how cold/warm was the impact wrench? - was ist below let's say 4°C/ 40°F ?
If you have a little too much moisture in the compressed air, the wrench then starts to freeze inside and wont work any longer.
2,260
I had a Snap-on 1/4" & a 3/8" air ratchet both fail about the same time- working fine, then they stopped & just blew air as you described.
(they were probably 30+ years old, but lightly used.)
Turns out there is a small neoprene "button" that seals the air either off or through the tool, when you press the lever. This seal had disintegrated in both tools. A quick disassembly, cleaning, and seal replacement was all it took.
KennysNewFarm
MX5800
Dec 28, 2017
220
Missouri
Diagram of a typical IR impact gun. Maybe this will help if you decide to break it down.
luc.who
Lewisberry PA
Thanks for all the help.
I brought the wrench in from the outside garage yesterday, wondering if the cold temps we have had could have slowed the oil. Took it out to the garage this morning, and cycled the forward reverse switches and it worked fine.
I did find the diagrams on the wrench and how to take it apart. I use the wrench so infrequently that it may have 10 hours on it.
Thanks for all your help guys, really appreciate it.
Tooljunkie
May 13, 2014
4,150
29
Water in airline,froze in the air inlet screen. Drain the air tank.
Oil with air tool oil and you should be fine. Oil as in 7-10 drops into air inlet.
On back of some IR impacts is a flush grease fitting. You need a contact tip to grease the hammer. I have an Ir impact that i have been beating the hell out of for 14 years. It still pounds like the day it was born.
luc.who
Lewisberry PA
Thanks Frank. I will add some oil to the gun and drain the compressor.
