Hydraulic fluid leak when hot?
2,342
Same problems on my L3540, 950 hrs.
3. Did you do anything, when breaking apart the engine 1/2 from the transmission 1/2 of the tractor, regarding the "front axle rocking restrictor" "special tool" on pg. 133 of the WSM?
Third question is about all I can help you with.
The front axle of the tractor is able to rotate around a pin at the center of the tractor. One wheel can move down and the other moves up like a see-saw to act as simple suspension on the tractor. The rear wheels hold the front of the tractor in a normal position but you are removing the front from the rear wheel support (bell housing). So you need to block the front of the tractor to the front axle so it doesn’t flop to the side when disconnected from the rear wheels.
You can see in the pictures where the floor jack is supporting the front on a 4x4. That may be enough but I would suggest you get some blocking at the front axle also.
On the RTV sealant can you just order the 3 bond so you know it is the correct material? I doubt it is really that necessary but also would be annoying if it failed and you have to redo the work.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Have you guys with leaking fluid from the propeller shaft seal seen this bulletin? I many ( most!) cases this leak can be rectified by pushing the seal sleeve back into position and installing this sleeve kit! It was a mandatory upgrade but it is obvious many of them never were completed. ( this applies to early 60 series tractors as well because Kubota decided not to include this spacer in early 60's for some reason!
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
Have mercy! Do I suddenly need this obviously expensive special tool set? This is getting deep into the HST section, instead of just seals at the surface. Mine is an L3540, 2009 model, s.n. 30664.
Please advise - I am looking to start this work next week.
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
You're going to want to get 40, 50, and both of 60. 60 is a sleeve, that has rubber on the inside to seal the against, the shaft, then the seal seals against that sleeve. There is one behind the bearing, and one in front of. You'll have to split the tractor to remove it, it's not a hard job, but it can be time consuming. I would also suggest replacing the input seal, and if the clutch disc is wet from the oil, replace that too. Would hate to see a guy get it all done and have his clutch slip later because of the oil on the surface. If you catch it right away, there's a good chance the disc will be ok, but if you continue to run it, that oil will sling around in there and soak that disc. The biggest trick is, that coupler, 20, will not come out of the shaft hole, when you go to remove the shaft, it will stay in the transmission. You'll have to get ahold of it and either put it on the shaft by luck, or put it back on the output shaft in the transmission, again, its a trick.
Mine would start leaking when hot, but the pour was only out the weep pin and would have been ounces. I decided to fix it after seeing it happen about 3 times.
1. In your response, post #6, you talked about the coupling 020 falling off the shaft (FWD propeller shaft). I have mine split and have hit the point that I am looking at the shaft, before pulling it out and am concerned about if I'll be able to get it back on without having to pull the transmission! It was a job to this point. The WSM calls for pulling the transmission and pulling that shaft out of the back side. OUCH! Am I going to be able to replace the shaft without doing that? How about tipping the rear half of the tractor backwards just a bit so maybe the the coupling will stay on the back shaft? Hints and help, please.
2. I found drips hanging from the bottom of the input shaft case (the case that holds the input shaft). I'd wipe it and it would be wet again. It seemed that it was coming from that point, as if the gasket was bad. When I removed the case, the gasket looked fine so I could not detect that it was leaking from the bottom of the gasket. All the bolts seemed the same tightness. The input shaft seal itself seems smooth and pliable and the seal surface on the shaft was smooth. Any chance it was the gasket? The reason I ask is of course I'm going to put in a new input shaft seal but I am concerned about getting the FWD propeller shaft back in place.
3. My clutch was behaving fine but I am considering pulling it and inspecting the disk. My concern about that is the alignment issue. Do you just eyeball the alignment and is it a big deal to get it to all fit back together. I've done several cars before and only eyeballed it but that was easier since I only had to pick up a moderately heavy transmission and wiggle it around, only having to align the input shaft. With this tractor, I've got to move 1/2 of a tractor and align about 6 mounting studs and a transmission input shaft. Hints and help, please.
4. Just looking at the exterior of my FWD propeller shaft seal, it looks totally in tact. No damage at all. Yet I am afraid not to try to replace it - I don't want to have to split this thing again if I can avoid it. I have to rent a trailer and haul it 60 miles to my house to work on, so once is best.
Thanks for all help.
la724
l3540 tractor, la724 FEL, brush hog, box blade, 2 thumb grapples
May 26, 2015
50
Punta Gorda florida
Number 20 did fall off the shaft on mine. I was able to put it back on the inner shaft with a looong screwdriver. It was not too bad to get it on just had to balance it right on the screw driver. Patience was the key to it. (although I was panicking about the thought of having to disassemble the trans!) Your idea of tipping the trans up is solid, I would try that if I had to do it again! I would definitely change the seal even is it looks good! (you know it too) I am 100 percent sure mine was leaking out of the input seal so make sure you change that also!
Good luck!
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
Good luck!
Were you able to pull the prop shaft out from the front (clutch area)? Please tell me you didn't have to split the HST. Mine has a large frame for the big Kubota backhoe in the way.
I now see you didn't have to split the HST. How were you able to pull the shaft out? Mine seems to only move back and forth a 1/4 inch or so. Tips on pulling the shaft out?
la724
May 26, 2015
50
Punta Gorda florida
Also on the clutch, same as a car, just bigger stuff. I cleaned mine which was soaked and it has been fine 6 years later! Eyeball it and also put your fingers in the open areas of the pressure plate where you can see the edge of the disk with everything installed to make sure it is centered. Mine went right together, no issues.
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
Regarding the prop shaft, how were you able to pull the shaft out? Mine seems to only move back and forth a 1/4 inch or so. Tips on pulling the shaft out?
By the way, I cannot tell you how much I appreciate your responding.
la724
May 26, 2015
50
Punta Gorda florida
I pulled mine out with pliers Its been a while but maybe the seal is holding it in? Be careful of the splines.
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
You have been a Godsend. I am sitting beside the tractor right now and am going to pad the shaft and grab it with pliers. You've inspired me to add some more pics to this wonderful article.
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
Did you cut out the old seal or pull the shaft 1st, then work it out? It's tight so I am concerned about cutting the seal and scratching the shaft surface.
la724
May 26, 2015
50
Punta Gorda florida
I did not cut it and I don't recommend that. If anything drill a small hole in the seal and insert a wood type screw (course thread) and pull it out with the screw. I don't recall an issue with pulling the shaft. I pulled the shaft to change the bearing but my old one was fine and I did not need to replace it. If you can change the seal without pulling the shaft then don't pull the shaft. I'm going to look at the diagram as I said It's been a while
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
I have the WSM and the parts lists on this computer if you want me to look at anything.
When I pull on the shaft, it easily pulls 1/8 inch back and forth. If I pull quickly, it's almost like it's hitting a mechanical stop, almost like a clip around the shaft bumping into the back of the bearing or something. The diagram does not show anything like that. I'm going to upload the parts diagram (I hope).
eck1901
L3540
Jun 12, 2017
34
Birmingham, AL
Did you get 60 out also?, if so do you have room to drill a hole in the seal?
No, 60 is still in the seal. It's tight in there and I haven't tried to move it. I don't see a good way to grip it. Perhaps I could use some needle nose. The seal rides on it so I am concerned about scratching it.
