how to replacement Ignition Switch
Spinoza
L2900
Apr 28, 2019
Walpole Maine
Hi Folks, will somebody help me with Instructions as to how to replace my Ignition Switch on Kubota L2900. A reference to where I might purchase a new one, also, Thank you.
5,442
Your going to have to be a little more clear as kubota never made a L900.
And I'm not going to guess what model you really have, as you didn't even put it in your profile.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Should just have to screw the ring off the front where the key goes in and slip it out of the dash. I don't know if it plugs in or wires in, I've seen both. If it wires in do one wire at a time and transfer them to the new switch so you don't get anything mixed up.
New switch, I'd just go to your local dealer if possible that way you know you're getting the correct part.
1,050
You may also have to figure out how to remove the dash to be able to access the rear side to install the switch
chief36chevy
BX2360
Oct 21, 2018
29
Annville
Can someone help me how I can remove the ignition switch on a BX2360? I tried to remove the outer ring but was scared the I would break it.
4,263
re:bx2360
from parts diagram....possibly
remove under dash screen
disconnect battery
remove ign sw trim nut
push through hole
unplug switch from harness...
seems that simple
