how to remove pin bushing on end arm link
L245dtRCA
L245dt, box scraper, 6 way blade, FEL, 4'Howse rotary mower
Jul 18, 2018
Molalla, Oregon
So I think I found an end arm link for my L245dt through Orange Tractor Talks
this is huge since the tractor was dead without it. Brought the part to a machinist, said he'd build a brace, took it to a welder and viola! As expected the brace wouldn't fit due to clearance issues, but the welder just welded the cast iron parts. "it will be stronger than the original cast" yada yada yada
broke after about 1 hour of use
Now I've found a replacement, which is huge. 37720-43910 is discontinued by Kubota and unavailable in general. So there's a bushing inside the arm which is cracked. How do I get it out in order to replace it? (part 34150-13430) which is still available!
4,464
One method would be to take a hack saw blade and slowly cut thru the bushing at any easy spot. Be careful to cut in a parallel position to the bushing and do not cut past the bushing. It should easily collapse and come out.
If you have a press, or know someone who does, you may just press it out.
5,318
Find a dowl that just fits inside the bushing, fill the cavity 1/2 full of grease, then using a hammer drive the dowel down and the bushing will be forced out of the part. ;)
JohnDB
M4500DT
Jun 9, 2018
378
NZ
I'd forgotten about that trick for getting sleeves out. Thanks for the reminder! Would love to hear if the OP is successful.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
I had never heard of this before. Just watched a couple videos of guys doing it. Great trick. It will come in handy for me at some point. Thanks for that.
