How to limit fluid loss during BX23S hydraulic filter change
ejb11235
BX23S, Braber BBR4G 4' Box Blade & LRM5G 5' landscape rake
Jan 20, 2022
458
330
Seattle, WA, USA
Hi folks ... my BX23S just went past 200 hours, so it's time to change the hydraulic filter. I'm wondering how much fluid loss I should expect and what I can do to limit it. I have a small quantity of UDT2 on hand.
Someone mentioned parking the tractor on an incline ... that seems easy ... I suppose I could also use the FEL to push down on something (maybe put some jack stands under the frame just in case).
I also saw mention of using a vacuum cleaner but it wasn't specifically for a BX ... is this something I should look into?
Thanks!
rgriggs
MX5400
Jun 2, 2024
Kansas
I used the shop vac trick. Worked great on my mx5400.
My son-in-law held it over the fill opening while I changed the filters.
ejb11235
Jan 20, 2022
458
330
Seattle, WA, USA
Thanks! For some dumb-ass reason, I was thinking you had to put the vacuum over the screen filter opening ... I forgot about the fill opening. That seems quite straight-forward.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
766
666
E.
can someone educate me.... I know I am really old school / old school..... and maybe not too book smart....
we would simply clean the area well and catch / reuse any fluid in a clean pan and reuse.
Clean and non contaminated back into use?
am I missing something on this recurring topic?
6,473
Don't take this as gospel. I usually change fluid and filter on my BX.
If I recall correctly, when just changing filter, I only lost the contents of the filter and maybe a cup or so.....maybe 2 quarts total.
Left the fill plug in and had the new filter ready to go....
If you open the screen filter up, everything will dump.
ejb11235
Jan 20, 2022
458
330
Seattle, WA, USA
Thanks, this is helpful. I hadn't planned on completely changing out the fluid ... I replaced it at 50 hours, and the book doesn't call for changing at 200 hours. But at a minimum I will plan on buying some more UDT2 when I get the filter so I can replace what's lost.
JimDeL
Aug 31, 2022
344
381
Austintown, Ohio
Changed mine about a week ago. Lost contents of the filter, and maybe half a pint more.
Most of what I lost ran down my arm and dripped off my elbow. :rolleyes:
ejb11235
Jan 20, 2022
458
330
Seattle, WA, USA
This is getting better and better! I think I'll tilt the tractor and just work quickly. I can't remember if you can even change the filter with OEM guard plate installed, but I have a detachable after-market guard, so I'll have good access.
2,751
I think IF you are prepared and have the new filter handy ONCE under the machine - the amount of fluid you lose will be a red solo cup - hell you will get more ON YOU than the ground!!!!!
ejb11235
Jan 20, 2022
458
330
Seattle, WA, USA
Perfect. I know how to move quickly!
6,473
Jim - - thanks for confirming my recollection. (y)
It was a few years ago that I did my swap.
JonM
Kubota Grand L6060
Nov 29, 2024
42
73
wisconsin
never reuse reclaimed fluids no matter how clean you think it is it doesnt take much trying to save 63cents to cost you several thousand in repairs.
5,559
I'm in the other camp, it is perfectly reasonable to reuse that oil providing it got dumped into a clean container.It's going back into the same machine it was just in, 10 minutes ago.
Maybe run it through a filter,if you feel inclined to do so, but there's nothing wrong with the oil.
5,559
Man, I'd love to know the story ! Like HOW it was put back onto the ground AND what did Toyota do for the owners ?
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
142
169
Amsterdam, NY
IDK - two very good questions. Maybe free oil changes for life? :rolleyes:
I'd say bent frame = "TOTALED" so it wouldn't matter how they put it down.
MapleLeafFarmer
Dec 2, 2019
766
666
E.
that frame folding was a very common problem with Toyotas in the lates 90's. Frame rust. Cost Toyota tonnes on cash as they provided new frames to some and complete vehicle buyback to other, etc..
Something like 1 1/2 million trucks got recalled and cost them $5 billion!!!
whitetiger
Nov 20, 2011
3,094
1,532
Kansas City, KS
The HST filter on the BX series tractors is pressure-fed. Like others have told you, you will only lose less than a quart of fluid.
Tipping the tractor, facing it uphill, and using a vacuum cleaner will make no difference.
ejb11235
Jan 20, 2022
458
330
Seattle, WA, USA
Fantastic! As I said previously, this is getting better and better, and you just made it better.
